related question --
if one uses the preout jacks on a receiver with preouts (again let's use the left channel as an example), is the left "speaker-out" terminal (red/black) on that same receiver still active? in other words, if i run an RCA cable from my left preout jack to an external amp, can i also then run a speaker cable from my receiver's (the same receiver) left speaker terminal to the left speaker, thereby using the external amp and the receivers left speaker (internal) amp to bi-amp the speaker? or, is the speaker-out terminal (the speaker binding posts) on the receiver necessarily inoperative when the pre-out jacks are in use?
and, is it correct to assume that one should ideally use identical amps to bi-amp a given speaker? it seems that it might produce inconsistent performance to use different amps (and certainly amps rated differently for power output) to bi-amp a single speaker.
