How do you adjust treble and bass on a Denon 4806?
TABCON
TABCON
My home theatre is running wonderfully, with absolutely no problems so far...BUT, I can't figure out how to adjust bass and treble. The whole system is flat, and thats fine, but it seems to need a bit more cowbell (treble).
Any ideas?
Respectfully submitted-
Tabcon
nova
nova
Press your tone defeat button. If tone defeat is off you can adjust bass and treble, if it is on you cannot.
MACCA350
MACCA350
If your talking about movies, check if the 'cinema eq' is turned on, as this will cut the highs. If it is on, try turning it off.
cheers:)
TABCON
TABCON
Yes I'm talking about movies and the eq is off. Can I still adjust?
Tabcon
MACCA350
MACCA350
Tabcon
Absolutely, on that 'cinema eq' page there should also be 'tone', select that and turn 'tone defeat' off then you can adjust 'bass' and 'treble'. You may have to do this when your playing a DD or DTS track.
cheers:)
