How do people pick in-ceiling speakers?
1
1655graff
It seems the hiddeness is big on their list. But how is coverage and quality of the sound addressed?
What I mean is, I'd think the sound is mainly on-axis directly below it and spread (diffused and reflected) or absorbed by the flooring material that's also directly below it.
Also, I see various sizes in diameter. Are these intended to help the quality? If so, what's the typical/recommended minimum for a typical HT/audio set up? How do people avoid "blasting" the listener seated below/slightly off-axis?
Thanks!
mazersteven
mazersteven
Thanks!
With the right speakers, and proper calibration.
Welcome to Speakercraft
AIM8 series
www.speakercraft.com
MDS
Some in-ceiling speakers have aimable tweeters and treble cut switches that may help too.
mazersteven
mazersteven
IMO aimable tweeters only don't do the job. An in-ceiling speaker with both aimable tweeters, and driver is the way to go. This way you can aim the speaker to the listening area.
mazersteven
mazersteven
This is one of the reasons Triad used an angled baffle which directs the front channel sound to the listener.
