REFERENCE LEVEL
Reference level is defined for film mixing and movie theaters. Every studio and movie theater is calibrated according to this level. It represents an average of 85dB for the regular speakers on the SPL meter (set on C weighting and Slow) using a band limited (500Hz to 2,000Hz) pink noise at the listening position. The peak level is set 20dB higher at 105db and the LFE peak level is set +10dB higher to a maximum of 115dB. The purpose of the +10 dB gain for the LFE channel is to increase the dynamic range of bass sound such as explosions and crashes. This means when the receiver master volume is set to 0dB, the regular speakers are expected to play a peak level of 105dB and the subwoofer is expected to produce a peak output level of 115dB. This is louder than most people can tolerate, so people normally set the master volume much lower than 0 when watching movies or listening to music. Furthermore, such loud bass level places a heavy burden on the subwoofer and requires multiple high-end subwoofers to produce it accurately.
Because 85dBC test tones can be very loud in a small home theater room and can damage hearing, receiver manufacturers through the encouragement by Dolby and THX decided that a reasonable test-tone level is 75dB and that is the level that most receivers use.
To summarize,
- Reference Level is 1.85v line level = 0dB VU meter = 85db playback level.
- 105dB Peak level = 0dB (Full Scale).
- 85dB Average Level = -20dB (Full Scale).
- 75dB Average Reference Level = -30dB (Full Scale).
- dBFS (Full Scale) = unit of measure for the amplitude of digital audio signals.
- The reference level is "0" dBFS, which is also the maximum signal amplitude that can be stored digitally in a typical digital audio recording system.
- Signals louder than 0dBFS just produce clipping (truncation of the waveform, hence distortion).
When calibrating your audio system, the receiver plays pink noise that is recorded at 75dB (-30dB FS). When the individual speaker levels are set to 75dB at the listening position, as measured by an SPL meter, the effects of speaker sensitivity and room acoustics are accounted for and the speakers are all level-matched against the Reference Level.
