how do i set my clock on the pioneer deh p4400???????
U Unregistered Guest Sep 24, 2004 #2 ? I got the same problem... (hey, if you find out, could you email me at REMOVED) or tell me where you found the info. thanks! Last edited by a moderator: May 20, 2013
U Unregistered Guest Sep 24, 2004 #3 found it! the clock is set by holding down the function button until the numbers start to blink, then using the arrow keys to adjust the clock.
