johnytheboy said:
i've got 3 rear lsi 9's, that are 33 lbs a piece, and i'm thinking won't attach to the wall too nicely..... stands, at roughly 48 inches to get them 2' above my head would be just asking for trouble with a 33lbs load on top
so i ask, what is your setup, what can you reccomend ?
I own LSi 9's and 7's.
The LSi 9's are not designed for wall attachment. Too heavy, yes, but Polk also doesn't recommend the 9's due to poor bass reinforcement when placed close to the wall.
I agree the 9's are too heavy for a standard tall stand. There may be a HD stand that will take the weight, but then why should you spend $500 for a set of stands for $900 speakers?
I have my 7's sitting on the top of bookcase units. I think it is toooo high, and will try moving my 7's down into the bookcase. But I don't think your 9's will like the bookcases due to bass reinforcement. If you had shorter bookcases, you could use try using the top shelf as the base for the 9's.
Bottom line, do you need 9's for your surrounds? 7's may be a friendly speaker for the surrounds.
