How can I make my music sound better?
Y
Yamaheart
I believed you had the volume on your MP3 player set to the MAX. You should never set the source volume to MAX, i.e. portable devices, computer. At least have the MP3 player's volume set at half-way and use the receiver's volume control.
Y
yeahman68
Okay, picture my room as a square, and now picture it as if the left side was missing, because that opens up into a living room (the listening doesn't happen there. So in this case, my room appears to look like a backwards C. The bottom base has a length of about 10-12 feet, but listening occurs only in the 4 feet because I directly face my speakers that way. The right width (only side in my room because the other doesn't exist as said above) is about 7 ft. The top base is the about 20 feet long, but again, it matches the wall parallel to it because that's where the listening occurs, and of course 8 ft. ceilings. So here's the dimensions : L W H, 12-7-8, but the real listening only happens happens in the first 4 ft of the bottom base. Hope I explained it clearly. So from I understand, my mp3 player shouldn't be used a source to play music through the speakers, but just through headphones? Why is that? The alternative I have is to directly rip the music to my ps3, which has good sound quality. As for what some of you are saying about sound quality in direct relation to the brand of the receiver; I thought onkyo was great for sound quality. I thought that a beginners' receiver such as the one I have had great sound quality, it just doesn't have all the technologies as the more expensive ones. To be honest, I really didn't know all this came into play. I thought it was just the speakers, and possibly the source.
Wafflesomd
Wafflesomd
That's not entirely true.
Most mp3 players today have pretty damn good amplification circuits and can handle outputting signal at max without any distortion.
But yes, I would turn it down to be on the safe side.
Y
yeahman68
Yeah I know, the thing is, I'm wondering if the speakers are really causing the problem. I just hope it isn't the room because then I'm kinda stuck where I am.
krzywica
krzywica
You could always try the front yard, the neighbors living room when they leave for work, or the garage to get a good direct comparison. :)
Y
yeahman68
Lol, but seriously, do you think the room has an influence?
GO-NAD!
GO-NAD!
I don't know about anybody else, but your dimensions confuse me. I think I understand the layout though. (Perhaps you could post a sketch?) Do I understand correctly that your listening position is 4 feet from your speakers? If so, that seems a bit close. And, if your speakers are facing the top or bottom of the "C", it means one of your speakers is closer to a sidewall boundary than the other, which may upset the balance somewhat. If the speakers were placed so that they faced the living room, it could improve the sound. It would definitely improve the sound heard in the living room, if that's important.
As for your MP3 player, I don't have one, nor have I even listened to one, so I really couldn't comment on that.
ski2xblack
ski2xblack
hell yes
The interaction of room and speakers is the greatest factor in the resulting sound. Even if you feel it doesn't pertain to the particular problem which inspired this thread, this is an aspect of system setup you don't want to neglect. By optimizing what you currently have it may help you to pinpoint it's weak spots more clearly, and help on your quest for improvement. As far as cost/benefit, room treatment and careful layout pay back far more than just about any upgrade I can think of.
