how can i get my coby 937 to play my t.v audio
blazingsun
can i use my codax out on my t.v to my cody 937 codax input, im not to sure about this stuff. ive tryed hooking up my audio out put on my t.v. to my aux1 and notthing happen, unless i need some type of speical av cable .?
Adam
Adam
Welcome to the forum!
We should be able to get you all set up, but I don't know what a cody 937 is, and a Google search didn't help me. Please give more information about that unit (such as manufacturer and full model number). Also, let us know which TV (manufacturer and model number) you own.
Thanks.
zhimbo
zhimbo
Well, I can help with the identification of the "coby 937":
I suspect it's this HTIB system.
blazingsun
here is the spec's
5.1-CHANNEL DVD PLAYER with INTEGRATED AMPLIFIER
Progressive scan DVD player
Super-slim design (2" high)
DVD, DVD±R/RW, CD, CD-R/RW, and JPEG compatible
Dolby digital decoder
Integrated digital AM/FM tuner with 50-station preset memory
5.1-channel audio for surround sound systems
Optical, digital, and analog AV outputs for home theater use
NTSC/PAL compatible
Convenient front panel and on-screen display
Multiple language, subtitle, and camera angle support
Picture zoom function
Parental lock control
100-240V automatic power switching
FCC/FDA approved & ETL listed
!HOME THEATER SPEAKERS!
5.1-channel surround sound system with 450W total output power
5 full-range satellite speakers (2.25" cone type)
Dedicated wooden subwoofer with tuned port for deep bass response (5.25" long-throw)
Convenient volume and bass level controls
Wall-mountable or desktop speaker design
the t.v i got is a "Toshiba MD20H63 20 in TV / DVD Combo " and has
Rear Input Connectors: Audio (RCA) x 1 · RF x 1
Rear Output Connectors: Coaxial Digital
Front Input Connectors: Audio (RCA) x 1
Headphone Jack: With Headphone Jack
no. 5
no. 5
If you sound system is the one that Zhimbo linked to, you have a small problem. The only audio output on your TV is S/PDIF and there is no S/PDIF input on that Coby.
However, you could use the headphone output from the TV to the stereo inputs on the Coby, all you would need is one of these cables.
blazingsun
that's a great idea thanks
however in my cody setup option it gives me the section between
-S/PDIF pcm & S/PDIF raw
but like you said there is no S/PDIF hook up on my unit, just aux 1,2 ,codax input and video input with the green,blue,red
It's weird the maunel says,I can hook it up to my t.v but has lack of infomation on how about I go around to do so.
I've been doing research on this issue and have notice that a lot of people of the same problem with there dvd threater system, Everything works but there t.v audio.
it's amazing out of all the fourms i've checked out your the only one that has some type of soution.
no. 5
no. 5
You're welcome. :)
Just remember that you will, in effect, have two volume controls.
S/PDIF PCM and S/PDIF RAW are selections for using the DVD player with speakers other than the included ones.
It appears the people at Coby were banking on the unit being used with a TV that has stereo RCA outputs.
That's why we get paid the big bucks. :p
Adam
Adam
Way to go, no. 5! The headphone jack to the rescue again. :D Those TV/DVD/VCR combos seem to often require that solution.
