Mitsubishi, eh?
I recently bought a WD-65731. I compared the picture quality in-store to a host of others; the real contenders were the Sony and the Samsung competitors. For me, the Mitsu really outshone everything else. A quick synopsis:
I took delivery on a Friday, which was good because I hadn't set up the HT system since I recently moved my family from Connecticut to Savannah GA. Thankfully the new "media room" (AKA bonus room) is air conditioned, because it was HOT work...
The 65731 was surprisingly light and easy to maneuver, given its 65" screen. To me, the appearance of the TV is terrific - extremely small bezel around the screen, and no speaker "wings" jutting out unnecessarily from the body. Connectors on the rear were well-spaced and easy to use. I especially like the dual-mode DVI- I/D connector for analog or digital PC inputs. There all also two native 1080P (if there is such a thing *cough* wobulation *cough*)- capable HDMI inputs, one of which will shortly host an XBox360 1080P w/HD-DVD when available.
The setup was simple - the Mitsu intelligently recognizes video sources then they are plugged in. I'd recommend that even if you think you know this stuff cold, that you read the manual before setup. This will avoid the need to reset to factory settings and start over, to remove unwanted video sources in the input menu. Don't say I didn't warn you.
So, time to turn on the set and watch the desired video source. That goes something like this:
1. Turn on set, wait for several minutes for anything to display because you thought it was prudent to use the 'power saving' option on power down and don't have the DVR hooked up yet.
2. Navigate to the options menu and turn off the 'power saving' option because that wait is really irritating and besides, if you're buying this thing you shouldn't be quibbling about a few extra bucks on the monthly electricity bill. That's the wife's job.
3. Go to the desired video source.
4. Stop screaming "
My Eyes! Oh God, My Eyes!", and return to the options menu. De-select 'Brilliant' mode and select 'normal' mode in the video options. Get a bright idea, and load a THX DVD in the player.
5. Go through the video calibration sequence, getting up once to curse and then hunt down those d*mned colored 'glasses'.
6. Finally, go to the desired video source.
7. Marvel at the incredible picture. Brightness, colors, tone, saturation all combine to produce a cinema-like experience. In fact, the picture is so good that, like good audio reproduction, it tends to emphasize shortcomings in the video source material. Very cool. Say to your friend beside you, "What rainbows? What the hell are you talking about?"
8. Note that black levels are not like the old Toshiba Cinema Series CRT, but that you really don't care because, well, look at that
picture, laddie!
So far, the WD 65731 has done very well. The sound level from the whirring 6-color wheel is acceptable, though I wish it were lower. The brightness is great. The bulb life is, I believe (and no, I'm not going to get up and check) claimed to be 5,000 hours at my present settings. I'll be ecstatic to get 3,000, and don't even think that's realistic. The picture quality is a marvel. HD content, especially Discovery Home Theater, can actually at times make you catch your breath.
Good luck to you with your choices, whatever they may be. I have read about many very (un)happy owners of a variety of products, including Mitsubishi, Sony, HP, Samsung, and Westinghouse. This was my experience, and I am sure that others' mileage may vary.
At any rate, count me one happy camper.
Cheers,
Matty K.
