Hmmmmm !!
Wellll.... I guess I cannot do this !
This set does not have the two round access holes. In fact the only removeable panel that looks like it will work is the rear lower panel, which has a factory seal tape on it. I have 2 1/2 yrs left on my warranty and so cannot break this seal.
I guess I'm paying for a cleaning!
I did look inside the bulb housing and there were several spider web strings visible even in that small area- there are probably a bunch of them inside this thing !
I'm thinking now that even if I get the webs cleaned out, they will return. I wonder how I can root the little b.....s out for good ?
