Hi All. Poked around this forum and on the internet for the past couple of weeks, and this seems to be the place for audio knowledge. So heres the story...
I moved into a new house a few weeks ago. The house was built for the previous owners with a bose system installed. 5.1 in the family room, two speakers in the dining room, two in the master bed, and two outside. All rooms wired up to the amps in a 2nd floor closet, main control unit in the family room and a secondary unit in the master. Then they got foreclosed on and did us the favor of removing all the hardware except for the outdoor speakers, the sub in the family room and the wiring. Thanks, jerks!
After some research here and around the web, i realized i could buy a receiver (yamaha, onkyo or denon), some ID speakers (The Speaker Company seems like a good deal) and some bose amps to fit into the closet and id be good to go and $5000 less in the hole than re-installing the bose. Sweet! But...
Im not sure what the consequences are to wiring "normal" speakers to a bose acoustimass module. Ive gathered that the module takes care of mid-range frequencies so the teeny bose cube speakers dont fry...so will that prevent a normal speaker (say a PTIW5 from tSc or Polk RC55i) from functioning properly? Or will it just keep the normal speakers from operating to their full capacity? I believe its the second but was hoping you folk with alot more knowledge than me could help.
Removing the module would require cutting a hole in the ceiling or the floor above, so it's definitely low on my list of options. Any help would be greatly appreciated, thanks!!!
