W
whatusay?
Please help me, if you can. I purchased a KLH S120ETH from a garage sale. When i got it home I plugged it in and it produces this horrible hum and when i turn the gain knob it sounds like the driver is hitting and rattles the walls. I havent hooked it up to anything yet. While trying to find info on this problem I keep reading about people with similar issue, removing 2 capacitors on the power supply board but nobody has shown any pictures or identifying labeling of the caps. So if anyone knows what I'm talking about, can you please clue me in. Thanks in advance,whatusay.
I have no idea of your technical competence. However we usually caution against the inexperienced servicing power supplies for reasons of safety.
Subs use switching power supplies. These fail commonly in just the manner you describe. These switching supplies are complex and generally not serviceable. I can not find details that these are known for particular cap failures. If that is so and you can find which caps, and solder in new ones, you might get away with it. However we usually caution against shot gun repairs. I can assure you from experience that switching power supplies are a nightmare to service and have significant fire risk.
Unfortunately that unit most likely needs recycling.
Speedskater
Speedskater
I did a quick search and most of the threads are about hum, so your not the only one.
Did you plug it into the AC with no other wires connected?
I think that it has RCA inputs, so make an input shorting plug out of an old junk RCA cable. Cut the cable to about 6 inches and twist the center conductor and shield together.
That power supply has failed, no doubt about it from the OPs description. It may well have ruined the driver already. It is not worth investing much money in.
W
whatusay?
Thanks for the answers. I did a little more research and found others that have had the same issue. And the solution was actually pretty simple, it was not grounded. Since the ac power supply cord is only 2 wires w/o a ground I replaced it with one that has 3 wires. I attached the ground wire to the chassis of the unit. All finished I plugged it in and no hum, turned it on still no hum, so shut it off hooked it all up and turned it on. Sounds good for the ten bucks I spent on it. Ive got a few other powered sub boxes that i have picked up from here and there, all just a piece from a system. Most common issue is the missing wire that connects from it to the receiver. I am not that savvy with electronics, but I do know enough to be safe and not fry myself or burn the house down. The question I have is, does anyone know of a site that has wiring schematics for electronic devices? If I had the schematics I could then make my own cords. Some need to be switched on by the receiver or the volume control is elsewhere, but anyway, I'm sure you all get the picture. And thanks again for the help. whatusay?
W
whatusay?
Hey Speedskater, thanks for your input. I figured out a solution with a little more research. It was a ground issue. Thanks again, whatusay?
W
whatusay?
Can you explain switching power supply for me? I'm aware of the ac needing to be converted to dc, but is there more to it than that. Are you referring to SMPS? I am not that familiar with the technology behind it. I've heard of the term, but never had it explained to me. I have looked it up, but I understand things better when they are explained to me. Books should have a glossary of lay-man words in them. Thanks again, whatusay?
Speedskater
Speedskater
I don't think that I could do a simple explanation of a SMPS on my best day.
Maybe someone could find a demo page.
