Horn speaker gallery
Whitey80
Whitey80
As a total noob, please explain the benefits of horn drivers, and why one would dedicated such a massive amount of space to them.
sholling
sholling
Function: Cup your hands around your mouth and yell. You've just simulated a horn.
Advantage: In general they play loud with very little power.
Disadvantage: Limited high frequency dispersion and not everyone likes the sound.
Y
yepimonfire
very efficient, horn loaded drivers can extend frequency response by anywhere from 1-3 octaves on the low end, if done correctly they dont sound "trumpety" big with people using tube amps because of the low output of them they need speakers with as much efficiency as possible. i know a guy who has horns with a 99db efficiency and using his low power tube amp he can reach levels high enough to permanently ruin your hearing. they usually work best if you mount a separate tweeter in its own enclosure not in a horn because horns do weird things to high frequencies (if they arent designed right they will "ring")
