Hey,
Try puting them @ the first reflection points.
Lean them on the wall or use something like a stool to place them at the proper height.
Proper placement usually takes trial and error.
Place in different locations. Turn on the tunes or use the clap test and listen for the sound that pleases or where the echo is diminished .
For flutter echo. The hand clap test works or the bic lighter flick also works.
A bass trap on the front wall placed @ a 45deg angle touching the ceiling will help by eleminating the relection that bounces off the rear wall.
The majority of reflections will bunch into the corners.
That is your flutter/echo.
You don't have to cover the whole corner.
Example:
[/URL][/IMG]
