F
flippo
Hi I curretntly Stream music from my computer to my Denon thru HDMI. Would there be any benefit to use an USB Dac instead? I'm thinking probably not but wanted to ask.
You're fine, just adds unneeded complexity, the dac in your Denon is fine. For a second there thought you might have the mistaken idea there might be some dating advice or something :)
XEagleDriver
XEagleDriver
LMAO, had the same thought.
Was momentarily worried this forum might be falling into the abyss.
Sent from my SM-G975U using Tapatalk
F
flippo
Bad choice of words. Like I said I'm not a believer that a Different Dac will make a sound diff. Just thinking that HDMI is keeping the system from playing full hi res files. Can only do up to 24/48 now.
F
flippo
XeagleDriver- When I was stationed at Scott AFB I saw a lot of F15's come in from factory and take off straight up.
XEagleDriver
XEagleDriver
One great jet!
