Hooking up my VCR/DVD Combo, Cable Box and HDTV and DVD Recorder
L
lillu
ok here is the deal, im trying to get rid of my vcr which is hook up to my cable box which is a standard cable box because i dont want to spend 16 bucks for a dvr. that is when the dvd recorder comes in. I cant get why i need to change source to av for my recorder but when i want to play the vcr i dont get a signal because the vcr is hooked up to my cable. do i need to get a switch or something else inorder to be on the cable instead of av. Thanks.
slipperybidness
slipperybidness
Sounds like something we can help you figure out. But, your description isn't very good. A better description of your components, how they are currently connected, and your goals would go a long way.
