Home theatre speaker recommendations
Magic79
I currently have 50" Plasma Panasonic Vierra, David 302 Sub in a 14' x 15' room.
Was looking at either Athena Micra 6 without sub or EMP ECA-44 with ECA-4's.
What would you recommend? I also do have an Infinity CC-1 center channel. Would this go with EMP ECA4's at front and rear?
Hope someone can help.
Thanks,
jcPanny
jcPanny
Satellite speakers
The metal enclosures and larger drivers in the EMP satelites should give you better performance than the Athena Micras and they got a decent review from this site. However, once you add a sub, the EMPs are over twice the price.
If you go with the Athena's you might find yourself wanting to upgrade. The EMPs are as good as it gets from a sattelite speaker and you would need full size bookshelf speakers to get a performance upgrade.
With either system, definetely get the matching center channel.
