Home Theatre Setup Help/Recommendations
W
WebMonkey
Currently I have the following speakers
Fronts Infinity Overture 3's
Center Infinity Prelude
Rear Infinity Overture 2's
Subwoofer Infinity SW 12
I was thinking about buying the following speakers and replacing the above.
NHT T6 for fronts
M6's for rears
M6 for center
Is the NHT system a better system than the Infinity Overtures?
My next question is on the receiver end.
If I use the Infinity speakers I was looking at going with seperates. Such as either an Anthem AV30 with a Anthem MCA 50 or a Parasound C2 with a Parasound A52.
Now if I buy the NHT system I was thinking of just using a regular AV receiver like a NAD T773, because of the price of spending on the speakers limiting my budget on a receiver.
If you had your choice which way would you guys go and why?
Thanks
