Gene DellaSala wrote an article and did a video a while back about home theatre power requirements. He mentioned that most people don't think about power when assembling a home theatre. I'm afraid I'm one of those people. I recently upgraded my speakers and electronics and was hoping to add a pair of SVS PB3000 subs but after watching Gene's video on power requirements I don't know whether I have enough wall power to add the two subs. I was hoping someone in the forum could give me some advice.
Gene gave an example in the article of a typical home theatre where he added the wattage of several components then divided by 4 (I don't know why he divided by 4). The result was 525 watts. This was less than the typical 1800 watts you get from a 15 A line so there was enough power for the components.
I have a dedicated 15 A line that all of my components are plugged into. I don't listen very loud, maybe minus 20 on average. I have a processor, three class A/B amplifiers (one 5 channel + two 3 channel amps), a plasma TV a Blue-Ray player and a sub. Anthem states the processor power consumption under a "typical load" is 60 W, the 5 channel amp is 550 W, the 3 channel amps are 350 W x 2, the plasma TV is 200 W, the Blue-Ray player 100 W and the sub 200 W RMS / 750 W (not sure what number to use with the sub but I'll use the 750 W). That totals 2360 W divided by 4 = 590 W. Each SVS PB3000 sub is 800 W continuous with 2500 W peak power. If I remove the old sub's 750 W (I'm going to sell the old sub) and add the SVS sub's 2500 W x 2 to the wattage of the other components and divide by 4, I get 1652 W. That's pretty close to the 1800 W max.
I doubt the SVS subs will ever be drawing 2500 W; I don't listen that loud. The two 3 channel amps only power the two rear surrounds and the four ceiling speakers so likely aren't consuming Anthem's stated 350 W x 2. Could I add the two SVS subs to the 15 A line or am I lacking adequate power?
Thanks for your comments.
Neil
Thank you for providing most of the needed information.
Below are my best guessitmate:
MCA525 - Anthem says 550 W typical, that's conservative, even 300 W is conservative.
MCA325 - Anthem says 350 W typical, again that's conservative, even 200 W is conservative.
Plasma TV - 200 W sounds about right.
Processor - 60 W sounds about right.
SVS PB3000 - Rated 800 W continuous so it could reach that high depending on the contents you play and the distance you sit. So who gave you the figure 200 RMX/750 W that makes little sense?
Blu-ray player - 100 W? I don't believe it, even a loaded Oppo 105 specified only 55 W. A regular Sony type specs says 15 W, so I would say 20 W should be plenty.
You can plug everything into a 15 A outlet, 20 A would be better obviously, but it should be a dedicated one. If not, since there could be 6-8 outlets fed by one 15 A circuit, you will have to make sure what else are plugged into the other outlets.
If you want to be more accurate, then you should use an online calculator to find out what your amplifiers consumed based on your required sound pressure level, distance, speaker impedance, sensitivities etc.
https://myhometheater.homestead.com/splcalculator.html
Once you get the answers you need from the calculator, report back and we can then let you know the predicted power consumption figures for you power amps and subwoofers and then you can do the rest of the math.
