Home Theatre Auditioning
O
OFile
I have a quick question:
I could potentially drop $15K - $20K on a home theatre system and have quotes from a number of different shops.
With different shops carrying different products, I have quotes on a number of different packages. Obviously I would only buy one package, and if they were smart would realize that I am talking with a number of dealers.
Knowing this, is it innapropriate to have a number of dealers go through the time and trouble to create a home theatre system for me to audition prior to commiting to a purchase. Would they refuse or be accomodating given the amount of money I could potentially contribute to their shop, given your previous experiences.
I would like to audition any setup I have been recommended to assist in allowing me to get the most bang for my buck. I don't mind the shops making a profit off of me, but I do not want to get hosed in the process.
Any advice is appreciated.
Thanks.
wilkenboy
wilkenboy
If you are going to drop that much money at a single time for a complete setup you should EXPECT that they will set it all up for you to preview and test drive at the shop, or alternatively in your home with a no-questions asked return policy.
You should also not hesistate to request swap-outs to do comparitive shopping component-by-component.
Think of it this way - would you trust a car salesman to deliver a car to your front door without your say in the features / add-ons they choose and a test drive?
I would make an audition of the proposed system "table-stakes" for working with any shop.
My opinion. I wish I had all of that to drop at a single time!
~Josh
jaxvon
jaxvon
No, it's totally appropriate to shop around and make the dealers work for their money. A good dealer will have no problem doing setups for you or even scheduling appointments so you can have a personal multi-hour audition. You should not give them your budget right away, just so that you can try to find out what sounds best before they start steering you towards the super high-end stuff.
A few tips:
-Don't get sucked into buying magic cables. They're a huge profit margin for stores and don't improve your sound. If you want pro-quality cables, check out Blue Jeans.
-With your kind of budget, don't neglect to include acoustical treatments and/or consultation. I'm assuming that you're not building a dedicated room, but rather adding equipment to an existing room with some minor modifications.
-If you have the ability to have a dedicated room for your HT or if you're going to be installing it in a room where you have excellent light control (as in you can eliminate most of the light), opting for a front projection display would be your best bet. In your budget class, you get the most display for your dollar with a projector, as well as a huge screen and the feeling of a true theater.
-Don't forget to budget for a good subwoofer. Subwoofers play a big roll in action movies, as well as music with low bass.
-If you can, opt for a setup with 3 identical towers across the front for a very uniform front soundstage. The rears for HT purposes tend to work better as bipoles, dipoles, or multipole speakers.
-Unless you can get a super deal at a shop, it's much more cost effective to purchase your projector from an online dealer like Visual Apex and your screen from a company like Carada (also an online seller).
df4801
If you dont mind doing some research.
I would suggest buying all the components yourself.
That way, you are not limited to what the dealer sells and also you will save thousands of dollars.
I have found most dealers to charge at least a 40-50% markup (in some cases, much more) over what I could buy the item for myself.
Then, they will still charge anywhere from $75-150/hr to install.
So, I suggest, buy all the pieces yourself, then you can still pay an installer to put together.
The Dukester
Many of the custom installers I have spoken with will arrange for you to visit installations they have already done to get an idea of the quality of their work and what products will sound like in a home if they think you are serious about a purchase/install. They usually ask the person if they will allow this when they do a job. I would be serious about it before invading someone else's home, but would do it in a heartbeat to check out the quality of their work and listen to products I am intrested in. Many showrooms will not give you a good representation of what products will do in your home, especially speakers or displays that have not been calibrated.
That's a great budget for a HT. You should be very pleased with what you can get for that. Spend your hard earned cash wisely and enjoy!
Duke
