So I've been trying to decide on what speakers to get for my HT room for a few years now (I don't jump into anything). I've looked at and auditioned many speakers from numerous manufacturers. Some are described as "musical" or "mainly for music listening" or "just for home theater". Now, I've been doing this hobby for a very long time, and I was under the impression that speakers were speakers. What I mean is if a speaker reproduces music well, it will work just fine for HT. Having said that, I used to sell A/V equipment and in one of my demo rooms there was a Klipsch Synergy setup (not that great, I know). Our demo material was usually action movies with lots of effects to showcase the system. I personally thought that system did a pretty good job of reproducing everything at a good level, while being a bit bright, was still pretty good. However, for music the towers sounded terrible to me. So that leads me to believe that some speakers can be good for HT, but not much else.
This lead me to do more research. What some seem to think is that the reason they sound good for HT is due to the horn tweeter being able to handle the peaks well without distorting. Ok, that sounds plausible. I decide that horn tweeters might be the way to go. I stumble across the HSU HB1. Gets great reviews for the most part and seems to be very good for the money. I go to find forum posts related to them and the reviews are less than stellar, but they cost $150 so how good could they really be? Then Andrew Jones decides to design a low cost set for Pioneer. My decision changes. I decide three towers for the front and bookshelf speakers for the rest. Sounds good to me, especially the price.
So, if you've made it this far I thank you, I was listening to my current setup which consists of what is in my sig. Pretty low end stuff. Sounds decent, but I'm not getting the clarity or transparency that I'm looking for. What I mean is that I want that "being there" experience that really sucks you into a movie, and my speakers are just not able to do it.
What manufacturers should I try to look at for speakers that are for 80% HT/20% music, but want something that can handle the peaks of HT without sacrificing sound quality for music? I've toyed with building my own, but I wouldn't really know what design would accomplish what I'm trying to do. I've read and re-read review after review, but never really see anything that makes me want to go out and buy something. The problem is purchasing the speakers, taking the time to mount them and calibrate them only to find I don't really like them. That's a lot of effort. I know that is the smart thing to do, but my wife will wonder why I keep swapping speakers as she thinks "it's fine" the way it is.
What do you guys think?
