So, I spent lots of hours compiling a set-up guide based on videos online, audioholics forums, videos, etc. I like diving deep technically to get everything correct and then, once optimal set up is achieved, forgetting it. Hence why I'm created this guide to remind myself should I need to do it again. I'm looking for anything I'm missing from the Audioholics faithful.
Setting up a Basic 5.1 Home Theater
1.) Find speaker placement
-Note: Refer to enthusiast videos to achieve optimal placement. Example from Audioholics:
2.) Find the subwoofer placement
Assumes that AVR is handling bass management. Set to LFE on sub or turn crossover on sub panel all the way up to 200Hz on sub
A. Place the sub in the listening position, put on material with which you are familiar.
B. Locate the best spot where the bass sounds the best through crawling on floor method
C. Switch positions and listen to the same material for similar results
3.) Run Audyssey MultEQ to set levels and distances with mic in optimal seating location at ear height
-Note: If the sub includes separate software to configure the sub (Paradigm PBK, SVS), run this first then Audyssey MultEQ in the AVR
-Note: If sub level is +/- 10 dB, this means the volume on the sub is set too high. Set volume in the middle
to start and adjust down or up until rerunning Audyssey MultEQ adjusts it <= 5 dB
4.) Verify that Audyssey set levels and distances correctly
A. Turn off Audyssey Room MultEQ (most people don't use Audyssey?) or use "reference" as this is the target curve determined by Audyssey.
-Note: Turn off Dynamic EQ as this mangles the sound
B. Set speakers to small (assumption: standard mini, bookshelf, or small tower set-up)
-Note: Refer to enthusiast website for typical crossover frequencies
C. Check distances for accuracy for Front L/R, Sat L/R with tape measure from each speaker to tip of nose at seating position
-Note: Do not adjust the Sub distance even if it greater than reality as the AVR compensates for time delay between sats and sub.
D. Set crossover for front/sat as specified by speaker manufacturer (default if not provided for front/sat: 80Hz or use SVS wizard)
-Note: Most AVRs have a low pass filter (LPF). Standard for Blu-Ray is 120Hz.
This might need adjustment based on the size of your speakers
E. Check Levels
a. Set master volume on AVR to 0.0 dB for "reference level" tuning
-Note: May have to adjust calibration for AVR from 0-98 scale to -70db to 18db
b. Calibrate SPL meter
-Weight: "C"
-Response: "Slow"
-Freq: "70" with the expectation that every reading should be +5dB for 75 dB reference
c. With SPL held vertically, cycle through Front L/R, Sat L/R, Sub and adust up/down
until SPL meter reads +5 dB on the meter
-Note: "C" weighting will not accurately measure low bass below 32Hz.
You must add approximately 7dB to compensate for lower sensitivity in that region
-Note: You may need to pump the volume of the center channel 1-3 dB to make dialogue clear. Similarly with the Sub to taste.
5.) Tweak Bass Output from AVR with "Subwoofer Level" Adjustment
A. Play material you know
B. Check the phase with the SPL meter in primary listening position. If the SPL goes up at 180, move it to 180, otherwise leave it as default "0"
C. Adjust using the "Subwoofer Level" in AVR or tweaking subwoofer levels section in AVR
...that's it.
Follow up questions:
Overall: Are there things that need tweaking or improved in the above guide?
1.) What if I'm running the surrounds wirelessly, each with their own separate mini-amp. How should the gain on the amps be set when interacting with the AVR?
2.) I'm confused about whether I should be using the Audyssey "reference" curve (options on my AVR: "reference" "flat" or "off" ) or should I turn off all the EQ and just set everything manually as described above. I mean, the Audyssey applies a room correction curve for room modes, right? And accounts for bass bloat/suck-outs? Unless I have the equipment to set the responses manually for the frequency range...shouldn't that just stay on "reference" ?
3.) Turning off Dynamic EQ seems to be not as good even at reference point 0 dB. Have I just gotten used to punched up bass? Should I be shutting this off and adjusting the bass up in the levels section?
4.) What is the interaction between the Front L/R crossover point and the low pass filter setting. Does 120Hz crossover indicate that it will be gradually rolled off below that in the Front L/R speakers and that information below 120 Hz will be reproduced by the sub? Seems like it...just wanted to make sure my logic doesn't have any flaws.
