Home Theater reciever & speakers. NEED HELP!
KASR
KASR
Im not a gear head & dont have the time to do all the extensive research & make a decision on tech stats!
But in the end, if you DO the research and make the educated decision, you'll be 100% glad you did - especially when it's all said and done. Resist the knee-jerk and really make an informed decision. The last thing you want, is to drop a load and then have buyers regret at the end.
fightinkraut
fightinkraut
Would like to here what other have to say in the speaker dept. Am going to look into the Ascend Acoustics per lsiberian's recommendation. I was going to pull the trigger on a complete EMP E5TI tower system but if I can get some better performing speakers for the same price why not!
I would have had a much harder time deciding between the EMP, Ascend, and Emotiva, but I have to have towers because of young children, wife felt safer with floor-standers then bookshelves on stands.
Emotiva is having a killer sale right now, I'd suggest you add them to your short list. A set up of the ERM 6.2 LCR with ERD-1 surrounds would be very close in price to the EMP set.
Oh, and I highly second KASR's recommendation...don't buy anything on an impulse unless you'd be stupid not to, and try to find the time between now and the end of Nov. to do some research in case you do want the EMP's, the sale ends Nov. 30 I believe.
Slater
Slater
Im doing the research but the overall convincing factor is to hearing them, cant go to the local best buy & do that..
Its crunch time & Ascend Acoustics is also having a deal which is over on Nov 30th...
