Home theater advice -- Is this a good setup?
I
index2020
Hi,
I'm a newbie in the HT world. I'm finally trying to setup a home theater system to go with my Samsung 1080p HDTV, RCN HD Cable Box, Western Digital HD TV, a regular DVD player and an iPod.
Constrains (1) I don't want to spend more than $1,200 on the receiver + speakers (2) we live in a small Manhattan apartment so I'm trying to avoid a 7+1 speaker setup. Am interested in high sound quality and future scalability.
This is what I have in mind --
- Onkyo TX-SR606 7.1 Channel Home Theater Receiver
- Polk Audio PSW111 Compact Powered 8-Inch Subwoofer
- 2 Polk Audio Monitor 30 Bookshelf Speakers OR 2 Polk TSi 100 Speakers
I know that all 7+1 speakers would have been great but in the interest of space I decided to look for 2+1 speakers.
Any thoughts on
(1) Are these speakers adequate for this receiver? Anything else in the same price bracket that's equally good?
(2) At the same price point is there another receiver I should be looking at?
(3) Will this receiver up-convert an S-video signal into HDMI 1080p?
(4) When I connect devices such as my cable box or a future BluRay player via HDMI, will the HDMI cable carry the sound as well or will I need a separate cable for the sound to go to the receiver?
Thanks in advance,
Davemcc
Davemcc
Thanks in advance,
1) The real question is "Is this receiver adequate for these speakers?" Yes, it is. You should really focus on the quality of the speakers and spend as much there as you can. I would really advise you to do as much speaker shopping as you can in person to listen to alternative speaker choices. I have a favorable opinion of Polk in general and if I were shopping in that price range, they would be high on my list of contenders, although I haven't heard those particular models.
The sub is a different story and I humbly suggest that there are better choices out there for the money. For this answer, I suggest that you make a separate post in the dedicated subwoofer forum since the replies are generally not universal at this price range and the specifics of you listening environment may play a factor in which sub is best for you.
2) Probably the Yamaha 663 is another to look at.
3) No. The Onkyo will transcode an analog signal to HDMI to a resolution of 1080i. There is some debate over that value of video conversion in the receiver. Chances are good that your TV has an adequate scaler/deinterlacer to convert the signal to it's native resolution as well or better than the receiver anyway. I'm leaning towards a Hippocratic Oath policy towards video processing in the receiver, i.e. First, do no harm. As long as the receiver doesn't degrade video quality, you should be fine. But having the option of either scaling or deinterlacing the video in the receiver gives you the option of checking for yourself the best manner and device of processing the signal.
4) Yes. HDMI is a one wire audio/video connection.
Midcow2
Midcow2
Go for speakers first listen too some
OP, Davemcc has already provided some good answers.
I would concentrate on speakers and go listen to some. There are speakers that you might like better than Polks. A good inexpensive choice is the Cambridge Audio S30s
http://spearitsound.amazonwebstore.com/Cambridge-Audio-S30-Speakers-Natural-Oak/M/B00196SJOI.htm?utm_campaign=froogle&utm_medium=organic&utm_source=froogle
or the Behringer 2030s
http://www.mondospettacoli.it/shop/behringer-truth-b2030p-b-2030-p-p-872.html?currency=USD
Having said, that I would look at a diffetent sub vendor than Polk. For inexpensive I would choose Dayton and if you can budget more either Hsu or SVS.
Onkyo is a good receiver brand. One of the best inexpensive, yet very good receivers for only $185 is a Yamaha RX-V363
http://www.fotoconnection.com/p86312-yamaha-rx-v363-51-channel-home-theater-receiver-black.html
