V
vaporlizard
I have a tabula rasa in the form of a room 27 x16 in studs that I have ready for home theater/ music room. I have wired the walls and am now struggling with the WAF for a 7.1 speaker system. Its looking like bookshelf in the front unless I can find some towers to appease the WAF.
I am looking @ Denon AVR 3805. My speakers of 30 years are my MacIntosh 3 ways. ( Once re- coned). Listening to jazz, blues and acoustic strings and percussion. I am learining that I am a bit of a dinosaur..what happened to 10 and 12 inch speakers. Yes, I do have a subwoofer with my Eosone 5.1. Any guidance to 7.1 speaker systems is greatly appreciated.
Thanks in advance
Buckeyefan 1
Buckeyefan 1
10" and 12" are still made. Cerwin Vega, KLH, and JBL produce quite a few - mainly for music. They are not as popular now as they were in the 80's and early 90's thanks to the new HT receivers and bass management. These processors cut out much of the low frequencies which can be set to off; 40; 60; 80; and 120Hz depending on the unit. Tower speakers and bookshelves have taken over for front mains. The largest you'll find now are dual and triple 8" woofers - extremely expensive and not necessary with a good sub. I have dual 7", and many feature single and double 6.5" drivers. They don't make up for the 12" and 15", but rely on the subwoofers for help. I think the midbass has much improved though. With the older 3 ways, you had a large woofer, a midrange and tweeter. Not much in the line of bidbass. There are some positives here. Since the amps don't rely on pushing power for woofers any longer (where all the power is needed), they use their current more efficiently to drive the mids and highs. Cleaner mids and highs are the result. That leaves one to really invest in a superb sub with ample power and exact room placement. Without the sub, these towers just can't compete with the older shoe box type three and four ways. Two channel music can sound good with these new systems, but it takes 10x longer to tweak the system. I listen to smooth jazz in DTS Neo 6.1 Music, as well as Pure Direct. I've played with the parametric eq, sub, and speaker placements for weeks, and finally have it set to where I like it. The surround is fantastic. Finally, you ask about a 7.1 speaker system. Start browsing the Paradigm and PSB sites for bookshelves and a center. You can't beat their drivers and looks. There's hundreds of other choices. Those are more mid to high end like your McIntosh. What is your budget range?
V
vaporlizard
Tabula Rasa
Many thanks, Buckeyefan 1. I'm thinking around $5K for speakers. It sounds like a mixture of good news/ bad news. I am planning to audition multiple configurations when the room is finished out. I had thought about using my current Mac 3 ways and maybe a Mac center. As I understand the vast majority of sound iin regard to critical listening is emanating from the front and center speakers, yes, no? I can see where the sub is critical to the setup. My room is over a 3 car garage with a 16" deep floor full of insulation. I really dislike mushy bass so I am thinking a front firing front ported sub.
I am scouting the area to audtion your setup if possible.
Thanks again
