I was going to recommend the same two places Leprkon did.
Looking at the pictures of the white van speakers, the boxes sure are handsome. But are they well built? Knock on them like you'd knock on a front door; if they're solid and quiet, that's good. If they're hollow sounding and loud, that's bad.
Next, make sure they don't leak air at the joints. Hard to do, but usually you can shine a flashlight up against the joints and peek inside (after you remove the speakers) and see if any light comes through.
Even if the speaker boxes fail these tests, the game's not over. Leaky joints can be caulked from the inside and made airtight, and noisey cabinets can be dampened with added internal bracing and/or glued material inside like roofing material or dynamat.
You should be able to calculate the interior volume of the boxes by measuring the outside dimensions, then subtracting the thickness of the walls. Then when you go to pick the woofer(s), you'll know which ones will fit best in the airspace you have. If they're ported, the ports can be sealed, etc.
Good luck! When you're done, you'll have the best sounding Pro Audio speakers on the planet!
