Hello all,
Amateur and budding audio freq here.  I've set up a new system and would like some insight into how I can optimize it a bit.  Attached is my SPL and looking to see what I can do to improve it.  The 30 Hz peak is VERY noticeable as the entire place shakes like the stay-puff marshmallow man is inbound (cool, but not great for movies etc).  And the 400 hz dip is very noticeable during a frequency sweep, but I hadn't noticed it other than noticing things are a bit "off" during listening.  My biggest beef during normal listening (both music and HT) is that the volume needs to be adjusted regularly.  I think it's the peaks and troughs depending on the range of sound (ie lower, bassy songs vs higher or explosions vs ambient high effects).
My system/setup:
Room is 20ftx40ft with 15ft ceilings.  Mostly brick and hardwood.
System is Marantz SR7007 with Audyssey MultEQ, DefTech 8060 towers, 8040 center and a SVS SB-13Ultra sub.  MultiEQ XT on, Dynamic EQ on at reference, crossovers: front:60Hz, center=80hz, Surround=150hz
Thanks for any help you can give.
-Brian
