I live near a very awesome builder; Scott Selvidge. He does a lot of 'on the side' builds and does so to a superb quality. I've been talking to him about an HT DIY with Scanspeak drivers and he asked me to do a listening test of some bookshelves he has. One incorporates a 7" revelator and dome scanspeak setup. The other used Swans drivers, and I honestly have no idea which is which. The big deal here is that the Swans are a very small fraction of the price of the Scans he builds.
Here's Scott's website:
http://www.schilacoustics.com/home.html
The HiVis weight about 19lbs/each. The scans weigh about 54lbs each. The scans have granite top and bottom, about 1" thick. If you check
this link you'll see a cutout image of how Scott build's the Scans. I believe he said the Hivis use a pre-made cabinet.
I put the bookshelves ~13" on each side of the TV, and about 20" from the wall, simulating a real listening environment for me.
I did about an hour session and am really amazed how good the swans sound. The scan's lower end is more robust, but overall it's very hard to tell any differences myself. Additionally, the Swan uses a 5" driver, where the Scan set uses a 7" driver, so there's a solid explanation for the Scan sounding more robust. There were a couple songs that seemed to bring out a bit of shreekyness, I'm thinking in the 2khz-3k range, but first listen was very pleasant.
I tried a range of music from Peter Gabriel, Coldplay, Michael Jackson, Natalie Merchant, and a few others here and there. I even put it through the paces on a couple of my fave rap songs and both sounded phenomenal. A couple times I even thought the Swans sounded better. Overall I'm biased toward Scan and they seem to be a tad more transparent but so little I'm not even sure it's worth mentioning. The biggest difference was the Scans simply had more impact in the chest. Short of that, I really haven't noticed anything that's significantly different.
I'll keep doing some ear tests throughout the week; had to stop for now.
My wife said she really likes the look of the Scans; she said if she could make the hivis in a darker wood like the Scans she'd take those.
Oh, and my back hates those Scans.
I attached a few plots for your enjoyment. File names are labeled according to the Frequency range I've focused on.
