Home audio advice needed
AdamA35
Looking to be pushed in the right direction. I am looking to power 8 total 8ohm speakers into 4 independent volume controlled zones, two speakers per zone. Each zone will play the same music, I just need to be able to turn on and off and control the volume to each zone individually. For reference, two zones are outside, one facing the pool, one at the fire pit. One is in the pool house and the other is under the covered patio area attached to the pool house. Looking for suggestions on how to do this and what to buy. I thought I knew how to do it, but there are so many different variables and factors I’ve found while searching that I am now totally lost. I’ve found a few 4 zone amps with the volume the control I need but I then need a receiver with Bluetooth. I’d like to try to keep it all in one, but also on the cheaper side seeing that it won’t be used year round as I live in the northeast. I’ve found some all in one, Receiver/Amp with the volume controls I need, but the price range is huge. Any suggestions would be greatly appreciated. Thanks
E
erpauls
Not necessarily a cheap option but have you considered doing Sonos amps? You wouldn't have to have a receiver and it would allow you to play all zones the same or independently.
