Hello all... I was playing around tonight (the better half is out
) and I took my Paradigm Mon 7s and put them on some paint buckets to raise the height of them. yeah I know but that's all I had laying around that was the same height... Anyway, I will try to describe the difference. The sound opened up and I immediately noticed a
HUGE in the imaging. I actually got up and check to see if my center channel was on. the sound stage was much wider and the sound seemed fuller. I would have never though raising the mains 7.5 inches would have made that much difference, but it sure did.
Has anybody else noticed this type of thing???
Who would have thought paint was the missing ingredient???
Anyway, on to make some better stand… And then paint them
