Guys;
I have been on a quest for a solution to find a way to run my large towers fullrange with LFE and still have separate powered subs too. The only way I can do it now with my pre/pro is to shut off the sub channel, run the mains large and then connect my powered subs to the L/R front outputs. This works pretty well but gives me no control over adjusting bass on my front speakers. For music that's fine but for movies, the bass can be a bit overwhelming at times for my wife.
Last night while doing bicep curls I came up to a solution for our bass dilemma of combining mixed bass+lfe back into the large front speakers. It requires a pre/pro that has 3 independent sub outputs.
All you would need to accomplish this is a high quality 4x2 analog mixer.
So, you would set your processor bass management as follows:
- Front speakers: Large
- Bass Out: LFE only (that way the bass from the fronts won’t get recombined again to the sub channel)
- Sub configuration: 3 sub mono mix
Then you take the Left Front + Left Sub outputs into the mixer to produce a “Left Front + Left Sub” mix. Feed that signal to the Left Front amplifier which connects to your Left Front speaker. Do the same for the Right channel.
Then take the 3rd sub output and feed to your additional powered subs.
By doing this, you now have the ability to independently control subwoofer level for your front channels and your powered subs. So you will still have stereo bass for the front L/R speakers but a mono mix of LFE + summed bass from all small channels.
Sounds great right? Well, there is one problem. I can’t find a single solution out there for a basic high quality balanced 4x2 analog mixer. It doesn’t exist as far as I can see. The closest thing I found is from RANE but the specs on their mixer suck. WTF?
Do you know of any high quality 4 input to 2 output balanced analog mixers? I’m all ears if you do.
