High Pitch Whine Coming From Speakers when Gaming
Beatmatcher247
I just got my new gaming rig done and it really cooks but the problem i'm having is a high-pitch, not super loud but definately noticeable and very annoying coming through my speakers only when a game fires up and the video card fans really get going.
I've got audio and video ran to marantz av7005 via hdmi and from there to display via hdmi.... i've got all my expensive gear plugged into a high end surge protector any ideas where to start tracing this sound down at?
I've tried various combinations of not running different things through the surge protector trying different receptacles etc... to no avail
I've got my preamp and amplifier in my entertainment center... so speaker cabling, signal cabling and power c abling is in close proximity i've really got know way around that. I never had a problem with the noise on my older pc when running sound via the optic cable.
any ideas what the culprit may be
Adam
Adam
Is the HDMI output on the PC on the video card? If so, I wonder if it's got an issue where it's sending out noise over that connection when either (a) it gets hot or (b) when the fans spool up.
Do you have another audio connection from the PC that you can try? If you have a sound card, it might be isolated from any noise on the video card.
Beatmatcher247
I played for a while and after about ten minutes of playing it seems to go away. LIke you said I think its caused when it spins up. Cause after the fan speed stabilizes with the load on it you can't hear it at all. I can live with that ;p.
The HDMI is on the video card yes.
