high/low voltage in same conduit
ctb_24
Is there any safe and effective way to run RG-6/RG-59 cable and romex wire (power cable) through the same piece of conduit. Is there some kind of device I can purchase to restore any disturbed signal? Also, what about CAT-5 and romex wire in the same piece of conduit? Finally, if I do have to run either of these in separate pieces of conduit, would it be okay to put them in the same trench?
thanks
jcrobso
Ther is no safe way!!!
RG6/59 and Cat 5 yes! High voltage and low voltage is a no no!
If the high voltage and the low are in different conduits you can put them in the same trench. John
Tom Andry
Tom Andry
Speaker of the House
Your question was already answered here. What are you hoping to gain by asking it again?
ctb_24
I accidentally posted the same thread twice. Sorry about that Tom and thanks for the response jcrobso.
