Hi everyone, I'm new so apologies for asking a HiFi not AV question but I can't seem to find the answer anywhere. I thought one of you may have come across this predicament. My HiFi set up, until last week was 2 x 8ohm speakers and a 4ohm sub all connected to the speaker posts of a 2 channel 8ohm amp. Last week I bought some other 8ohm speakers and decided to wire all 4 in sequence parallel. This works fine but the sub was humming. So I've connected the sub from a line out on the amp to the LFE or low level input on the sub using a split RCA. Personally I thought the sub sounded better when it was connected at high level ie. Speaker posts to high level input on sub using a neutrik speakon cable.
So my question is.... Is there a way to connect all 5 speakers incl the sub to just the 4 speaker posts on a 2 channel amp, without humming or overloading anything?
