<font color='#000000'>Hi all,
I'm new to HT and hi fi stuff, and need some opinions on what kind of setup I want...First off, 2 track stereo audio is of SUPREME importance. The main L/R speakers seemed like the utmost crucial piece of the puzzle, and I got a used pair of massive Klipsch KM-6 floorstanders for that, ...they 'seem' like they will be good (I only have a very old Sony TA-AX 295 component amp + CD player to audition them with so far , and they sound a bit small and lifeless although I can hear the smooth highs and good bass on certain CD's)..anyway, I'm sort of stuck on what I path to go for the best stereo playback, but also with something that I can eventually upgrade to a full 6.1 or 7.1 plackback system for audio and movies....Here's what I'm mulling over right now...
1. Get a slightly older , but high quality 100 watt amp dedicated to stereo audio playback , like a NAD or Adcom...
2. Get a midline full blown 6.1 or 7.1 receiver , like a Marantz or Denon..possibly even NAD ,but still run the crucial left and right mains for stereo audio to the dedicated amp....
3. My only audio/video source for now is going to be a DVD player that does SACD and/or DVD audio playback...I've read where the newer models will now let you have bass management, level control, etc from the analog outs of the DVD player, which I hear you have to use to take advantage of SACD's/DVD audio...eventually I may add a turntable for old times sake...
So those are the 3 things I'm thinking I need next....eventually adding in a pair of back surround and side sourround speakers..the TV is the last thing I would upgrade...a couple things I'm wondering are, is it possible to have the single stereo image alone playback thru all the eventual speakers? How easy is it to shift from that back to DTS or Dolby if I wanted to? Does that take a more sophisticated receiver?...and about the surround speakers...I have this idea of using a pair of Yorkville studio monitors that I have as the L/R side surround speakers and hanging them from the ceiling pointed as the listening area, ..and then adding some other type of big speakers for the rear L/R surrounds...possibly something as big as Magnepans hanging on the wall!...I know that surround sound to the surround speakers doesn't really require bigger speakers, but I'm envisioning having HUGE surround audio , with just the single stereo image going to all the speakers (if it's easily selectable via remote that is!)....My thinking is I could avoid a subwoofer alltogether this way, as my Klipsch KM's go down to 35Hz and sound quite massive. As you might be able to tell, I'm really trying to shoehorn a good , selectable-if-I-so-choose DTS, Dolby,etc surround sound for audio/video , but then still have the best possible arrangement for room filling stereo playback thru all the speakers if possible.....</font>
