update talked to actual service tech yesterday went threw the whole problem he said it sounds more like a main board went south on me or at least parts of it so ill send it to them and let them have a look at it cost of new board anywhere from 380,00 to 500.00 depends on model , thanks so much for ideas and help Gentlemen !!!
It certainly sounds like a major processing chip went out. This does sound like a software problem caused by hardware failure.
That is bad luck on a receiver of that value.
Honestly though, as I have said before it is nuts to put a bunch of delicate processing chips in the same case as 9 power amps.
When considering really expensive receivers stop and really consider going with a pre/pro and only external amps. That is the far better route for large major installations.
If I owned a unit like that I would expect it to fail, and when it did I would consider it my bad judgement purchasing it in the first place.
Those huge Atmos receivers are a total nonsense and to be avoided.
