Hey ALL, Need Help finding Info. On My Surround Sound Speakers!!!!
samsungson
samsungson
Can't Find the info anywhere!!:rolleyes:
Maybe someone here that is a Web Search Guru can help a fellow member out. :D
THANKS IN ADVANCE!!!
Make: Pioneer
Model Number: S-FCR200-k
Type: Surround Sound Speakers
Specs I Know:
Max Power: 100W
Impedance: 8 OHMS
Serial# UCAT010807UC
Davemcc
Davemcc
It's like trying to find a Trotsky in a Stalinist world. It's just "disappeared".
agarwalro
agarwalro
Odd! The only references I found were in other forums, no product pages.
Call Pioneer tech support.
samsungson
samsungson
Ya, thats probly the same one I kept finding. Thanks for helping thoe :).
I found on pioneers website their product line and I clicked OLDER PRODUCTs and found a series of speaker that was Very close to the Looks and Model Number. So the ones I found were probly the Model just After my Model.
Just Mist it!!! :rolleyes:
avaserfi
avaserfi
As I said, it just disappeared. Even forum pages that lead to info or images are dead links.
I haven't actually looked but you could try clicking the cached link to those articles/forums and you might see what used to be there. Just a thought if the up to date links don't work, look at the stored one ;).
samsungson
samsungson
Sounds Complicated to me. :D
I'm using 4 out of the 5 I purchased at a garage sale. :)
avaserfi
avaserfi
Pretty simple. Do the google search like normal then under the description of the site you will see two links "Cached - Similar Pages." Just click Cached and it will go to a stored version of the page that hasn't been updated in a certain time frame with the search term highlighted. Now, this isn't guaranteed to work but it generally does.
