Jblack223
Hello all and thanks up front for your help. I have a vintage Marantz 2325 that is perfect. I currently power two kliptch pa type speakers and 2 large Yamaha pa type speakers on the 2 nod channel. I purchased, and got a very good deal, on a Bose 402 system with the bose equalizer I want to use this system for outdoor parties on an as needed basis. I need to know how to connect this to my receiver. Please help.
crossedover
crossedover
You can go through to tape loop to connect it. But just a note, those speakers are rated f6 -10dbs @70hz so you wont be getting much mid bass unless your adding a subwoofer system,
Jblack223
Thanks
Could you explain how to do that for me?
crossedover
crossedover
Tape out to the EQ, then EQ back to tape in, then activate the loop on the front panel.
markw
that Bose eq is going to kerfutz things up big time.
The problem you are going to have is that All speakers, not just the Bose speakers, will be getting the "benefit" of the Bose specific Equalizer. Now, this will be great for your Bose speakers since the speakers and eq were designed as a matching pair, but it won't be so great for the other, non-Bose speakers you are running.
Your best bet is to get a separate power amp, split the preamp/main amp, put in a pair of with a "Y" splitters, feed one side signal back into the Marantz to feed the non-Bose speakers directly from the Marantz, and the other leg to the Bose amp, then to the other power amp, and then to the Bose speakers.
that, and it will also alleviate the potential problems of overstressing that amp with the boost that eq will apply and/or running more than two pairs of speakers simultaneously. It would be a shame to smoke that nice receiver.
