G
gateagent75
I am 54yr old houswife who attemps all our audio/video. I have been struggling with Integra DTR-7.4. want to hook up projector and plasma tv. I have the dvd running on both screens but I would like the video from the tv to also work on the projector screen. :confused:I have tried and tried to hook and rehook ..configure and reconfigure with no luck. Go easy on the lingo, I am not by any means a professional but any and all help would be appreciated.
Davemcc
Davemcc
Are you using a cable or satellite box for your TV viewing? If you are just using the off-air antenna, does you TV have a video output?
Lordoftherings
Lordoftherings
If you want some help, you have to stick around.
Because we got some questions to ask you first.
Please clarify the following:
1. What do you mean by video from the tv?
2. You mentioned other things, but is this the only problem you are having?
Thanks
