Hi brian, thanks for the response.
I was thinking after, I can square that room off, if I replace that angled load-bearing wall with a beam, and put a non-structural wall with a door in. So, the ceiling will be the thickness of the beam lower in that little triangle. Do you think that will cause problems? I know it's not optimal, but it'll work with the space I have.
...Door|. /......................|
.........|.........................| 12'8"
..................14'6"
