L
Lowfront
Alright I'm having a sub issue...
I recently moved into my basement....
The only corner I can use is the front left...
the problem is there is a closet right there
{closet with components to the right side}----tv inside the wall
thats how it is left to right I got the closet with all my components in it to the right....right after the closet the tv is inside the wall...
Now I have the sub in front of the closet....Its pretty bad cause those hard bass parts end up rattleing the door there.....
Sould I try taking the door off and just putting the sub in the closet...not thrilled about the idea but i dont know........
also in the closet I have the second door open showing my components...??should I put the door back up and keep it closed?...
sorry if this is confunsing..
