Help! Yamaha RX-3800 receiver speaker configurations
Liquid Air
Liquid Air
During GUI auto set up my front L/R speakers white noise comes out of the surround L/R only. I did a firmware update factory reset I'm pretty good when it comes to the technical stuff. I tried to do a manual setup and no matter what I do I What everything reads correctly I still cannot separate the front signal combining with the surrounds. Any help is greatly apprciated as its baffling​
Is it just coming out of surrounds or both L/R and surrounds (at first you say surround only then you say its combining with surrounds)? You sure your speaker terminal wiring is correct?
