Aaa you are correct again, Yes Crutchfield tech which is where all the mis information started from hence I purchased the Yamaha because the said ABSOLUTELY it would work with the 901's. I do like the Yamaha now that I have it, ran the YPAO and the 901's sound great. Would you know if there a BIG difference?
I was contemplating purchasing the HK 3490 (stereo receiver) it has the correct connections that the active eq needs just to hear how the 901's will sound, if theres a big difference in the sound quality I'll have to make a few decision. If I don't hear any difference then I'll keep the Yamaha and return the HK. Any advice?
I would not bother. But if I were going to go with a separate amplifier, I would buy a power amp, not a receiver or integrated amp. The reason being, you are only planning on using the power amp portion of it, and you can get more power for your money that way.
As for hearing any difference, I would expect that you would hear a difference between:
- using the Bose equalizer with a power amp and with the receiver set to bypass its equalization, and
- just using the receiver with its equalization.
The reason being, the Bose equalizer is meant only to correct the frequency response of the speakers, not the effect of your room (which it obviously could not, as each room is different). YPAO will adjust according to those speakers in your room placed wherever you place them, so its equalization will be different.
Now, whether you would hear a difference between 2 above and using the Bose equalizer with rerunning YPAO to equalize for the room or not, is more questionable. If the Bose equalizer adds any noise, that could be worse. But it could also be that YPAO will be better able to deal with room effects, as it has limited ability to adjust the frequency response, as it has a finite number of bands of equalization that it can do. However, that does not necessarily mean that it will be worse, as it may also be that, due to room affects, it has to undo some of what the Bose equalizer does to the frequency response.
Now, if I were to hazard a guess, it would be that you would likely make the noise floor worse with using the Bose equalizer and a separate amplifier, as it is unlikely that input and output levels will be precisely suited for each other, and your Bose equalizer likely has a higher noise floor than the receiver anyway (though I am uncertain of that). And I doubt that there will be any very significant difference in the equalized result if you used YPAO to correct things in both cases.
So, again, I would not bother with buying a power amp or using the Bose equalizer. I would save the Bose equalizer, in case I ever wanted to use the speakers with a traditional stereo that does not automatically equalize, but I would not actually use it with this receiver.
