born2die
I have 3 sources going into the present televison dvd, Sky and a freeview box these are daisychained so that they input the television through 1 scart lead. Now the other half has bought a bigger second televison to mount on the wall for us in the evenings.
Now I need to get the signal from the current setup round the room to the televison on the wall and at the moment all I can see to do is to use a wireless sender but this seems expensive just to run the signal 10 feet is there some way of using a scart splitter and using a long scart lead.
I have just looked at these two choices (budget is tight at the moment)
http://www.argos.co.uk/static/Product/partNumber/5344273.htm
http://www.argos.co.uk/static/Product/partNumber/5345904.htm
are these any good and will I get any interferance as the sender and reciver are so close
any help would be great
many thanks in advance
Tristian
Tristian
