Hello,
I am looking for some advice for speaker placement in our new living room. It is a small townhouse, so we can't have a dedicated home theater room, and this will have to do. My wife is a music afficianado, and I am the movie guy, so both need to sound good. We have an Outlaw 1050 receiver and are buying Orb Audio speakers (6.1, most likely).
Please take a look at the attached floor plan and give me your advice on where to position the speakers. I realize that this shape is not ideal, but this is pretty much the only way to orient the furniture. The television (a 47" Sony LCD) will be on an articulating arm so that it can be angled towards the couch.
The 7'3" and 7'4" openings on the plan are open to other rooms (yes, I know we'll lose a lot of sound). The 4"11" stretch at the bottom is a fireplace. That whole wall is masonry and we cannot realistically run wire through it.
Specific thoughts to address if possible: can we mount the Orbs on or near the ceiling and angle them towards the listening position? Would stands work okay for the rear surrounds? If we put the front speakers on either side of the television, would they be too close together? If we put the left front channel by the club chair in the corner, would it be way too annoying for whoever is sitting in it?
Thanks in advance for your help!
Scott
