Jack Hammer said:
1. How do I use it to control zone 2 on my Denon 2805?
You need to put the original remote in Zone2 mode and then learn every command that you want to use to the URC300. I don't know if that remote allows you to relabel the main page device buttons and if it doesn't just pick one you don't currently use, like Aux. If it does, rename one of the main device buttons Zone2.
If the Denon remote has a specific button to enable Zone2, I think a logical choice for the URC300 would be to use a press-and-hold macro on the main device page button you use for zone2. Have the press-and-hold macro send the command to enable zone2 and then switch to the zone2 page where you will add all commands available for zone2.
2. Is there a way to add learned functions to Macros? I'm trying to have it automatically switch to the DVD control when I hit the HDMI input (learned from tv's remote) button while controlling my tv.
You should be able to use any command from any mode in a macro. You would need a macro on the button that switches to the HDMI input. Have it do the receiver switch to HDMI, switch to the DVD page and do whatever it needs to do and then end on the DVD page.
3. Is there any way to move the lcd touch functions around that are learned without just manually retyping the name in a new location and then relearning the button from the original remote?
No. Only the MX-800 and above that require their software to program the remote can do that. I usually label everything first and then learn the commands.
4. A lot of the controls I use from my original remotes get a "Failed" message while trying to learn them.
If the original remote uses standard IR frequencies and protocols there is practically nothing it can't learn. It can't learn from RF remotes or remotes that use protocols unknown to it or using frequencies above 100 kHz. It also can't learn 'toggle bit' commands (which are rare).
You can try various things to make learning go smoothly:
- Fresh batteries in both original remote and the URC300.
- Turn off any overhead flourescent lights.
- Vary the distance between the URC and the original remote. A few inches usually works best.
- Tap quickly vs press and hold the button on the original remote. Commands that repeat, like Volume+/- sometimes learn better if you hold the button on the original remote for a few seconds so the URC can see the entire sequence. Other commands work better if you just tap the original button.
