Help With Total Av Setup
Atomik
Fairly simple.... But have been rethinking things way too much...
TV- Samsung 40in 1080p - 2 HDMI in
Receiver w/ video upscaler - 1 HDMI out and all possible inputs
Cable - Analogue - RF and compsite output
DVD-Player/Recorder(built-in DVR) - Component output and RF/Composite Input
Ok wats the best way to connect this setup maximising the capability of the upscaler for the cable and dvd player hookup and using the upscaler to the dvd player/DVR.... if u're confused so am i. Ask me... to easily simplify the setup.
jcPanny
jcPanny
Video routing
Atomic,
Do you already have all this gear, or are you considering the purchase?
If you are in the market for a receiver, you should consider one in the $3-400 range like the Yamaha RX-V659. It will provide video switching of all of your component sources, but not HDMI. Purchase a quality Oppo DVD player or maybe HD-DVD to take advantage of your new set when watching movies. Connect the DVD and other HDMI sources directly to the TV.
If you already have the new receiver, allow it to convert all video to HDMI and experiement with the upscaling feature. It might be slightly better than the scaling in your samsung TV.
