help with system set up
tomitom
Hello to everybody . im gald i found this forum
i received for my birthday the folowing items and need some help with my set up option
i add links to the item that i have
i read over the internet regarding bi-wiring, my bi-wiring ready yamaha speakers and i would like to know if i should do that considering my amp have a low rms watts 50x2 or 40x5 watts
and if so how would i set it up !
im thinking if i will wire each speaker to 2 chanel that will give me 80watts per speaker am i right !?!
and i would like to know if that will harm in any way the speakers or the amp
http://harmanaudio.com/search_browse/product_detail.asp?urlMaterialNumber=AVR 145-Z
http://www.yamaha.com/yec/products/productdetail.html?CNTID=200120&CTID=5002900
jcPanny
jcPanny
Speaker connections
Tom,
There is no benefit to biwiring or likely little or no benefit to biamping with your entry level receiver. Any 14 AWG or 12 AWG speaker wire will work fine for the connections.
If you want to experiment with biamping, you could run the receiver in all channel stereo mode and connect the L/R mids and tweets to the Main and Surround speaker outputs. Since the receiver shares a power supply for all amp channels, it will deliver less power into each channel when driving 4 channels then it will driving just 2 channels.
