Help with Surround Sound Speakers
L
Luiz Vacanti
Hi Guys,
Looking forward to buy a pair of surround sound speakers. Please need your advice.
My current setup is:
Denon AVR - AVR-X3300W
Svs sb12-nsd
3 Affordable Accuracy bookshelf
Which one will be a better fit or if neither please give me some ideas, budget max $150 pair
Micca MB42X or
NHT SuperZero 2.1
My room is 10x10 feet, also atmos speakers will be a good idea?
Thanks for you help in advance,
Luiz V
K
KenM10759
Small room, Atmos would be tough to pull off though you could try a 5.1.2 system. I doubt you'd have space for 4 ceiling speakers.
As for the surrounds, I would just save up a little more and get another pair of the AA Monitors. If you can't wait, I'd take the NHT SuperZero 2.1 over the Micca MB42X.
William Lemmerhirt
William Lemmerhirt
I would get another pair of AA’s for surrounds. That’s a small room for Atmos but it could work as 5.1.2, as Ken said. 5.1.4 though will probably be too hard to do right. Unless you can move the couch forward(which you should as much as possible), it’s hard to properly place speakers, but that’s a really small room so I guess do what you can.
L
Luiz Vacanti
I think the AA will be too big for a surround on my room. Definitely I can only do two atmos, but I don't know if it is worth because of the size of the room.
Thanks
Luiz V
Drunkpenguin
Are in-wall and in-ceilings an option? I might go that route for that room with 5.1.2.
