This is the first time I've used a powered subwoofer, and I'm a little confused.
I currently have a Yamaha HTR-5730 receiver. It has a single subwoofer RCA output jack. The manual says, "When using a subwoofer with built-in amplifier, connect the input jack of the subwoofer system to this jack. This unit will direct low bass signals distributed from the front, center and/or surround channels to this jack in accordance with your SPEAKER SET selections. The LFE (low-frequency effeect) signals generated when Dolby Digital or DTS is decoded are also directed to this jack in accordance with your speaker set selections."
You can click on the image below to get close-ups.
<a href=http://www.yamaha.com/yec/products/backs/bHTR5730.htm#><img src=http://www.yamaha.com/yec/products/prod_images/HTR5730_backM.gif></a>
In the Sunfire True Super Junior manual, it says of the line level inputs: "Connect with RCA type patch cords to teh line level outputs of your receiver or preamp. If your receiver has a single sub/LFE output, connect it to the subwoofer's left input jack. There is no need to use the subwoofer's right input jack. "
However, there's also normal speaker level inputs, with line level "high-pass" outputs (not sure what that means). "These outputs are active whenever a signal is hooked up to the inputs of the subwoofer. This crossover is a passive network with a fixed crossover frequency of 70 Hz and a 6 dB per octave slope.
We recommend using this high-pass function with main/satellite speakres that are small and not designed to reproduce low frequencies. If your main speakers are capable of operating full range, then you will not need to use the high-pass function.
To use the high-pass outputs, connect the preamp outs on your preamp/receiver to the subwoofer's line level inputs using RCA patch dcords. Then connect a second patchcord from the subwoofer's outputs to the inputs of your main amplifier. This will alow your main speakers to operate at frequencies above 70 Hz and the subwoofer to operate at frequencies below 70 Hz."
So the question is, which way should I do it? I have Rega R3 front speakers with three drivers. The biggest is only 5", so I presumed I need a subwoofer. I don't know what is considered full range. The manual doesn't specify, and my Rega manual doesn't even say what the frequency range is. Also, I'm thoroughly confused with the last paragraph. Which input jacks in the receiver do I plug the subwoofer into??
<a href=http://www.sunfire.com/SuperJrPR.htm#owner><img src=http://www.sunfire.com/images/products_2005/primary_SUPERJRSUB.jpg></a>
Thanks.
